Green, walk if it's been crashed. It bends up the steering parts. Like the bike rides straight, but the bars veer to the right or left when looking down riding it.
BIG,
13: Open Loop (+) because you can tune/flash it with dynojet box or have it reflashed.
17: Closed Loop (-) because of the 02 in the loop, flash has to override the code, where some codes limp power.
13: No ABS (-) only if you're spoiled with staying upright with a locked front tire.
17: ABS (+) becomes standard at the end of the production run. I'm sold with all the pebbles at said stop sign.
13: A quick diagnosis (+) where if you install a coded part, it clears the dash within seconds.
17: A slow clearing (-) where it takes a lot of key turns before it clears the dash, short of dealer clearing it.
13: Performance mapping (+) the latest massage [seems like] where there are subtle changes including the ECU.
17: Just gets better (+) HP is no problem, we just open the faucet a year at a time and spread it over the map.
13: Nissan brake parts (+) where they are no problems with keeping costs down on a cocktail dress.
17: Brembo Special Edition (++) where the front master is race-production, but not race-race, but WOT a difference.
13: Idle cable (+/-) sure, nice to lower it for lowering the rpm for braking, not fighting a few hundred rpm's.
17: Vac/ECU idle (-/+) lost is the adjustment, but I don't miss it one bit. Can't beat E.
13: ECU's E (+) is the subtle jump in gens, where the mode buttons on first gen dash, moves up to the left switch.
17: E's ECU (only gets better) is just waiting for the next gen to have clutchless rev shifts, multi-axis Electronics, or whatever they come up with... WATT a dash that would be is touch screen next; no bulky switches.
* Last updated by: Hub on 4/11/2020 @ 6:27 AM *
