What is the low beam bulb type in a 2007 ZX14 ?
Created on: 04/21/09 05:17 PM
jrp0629
redtrace
Steven14
RE: ZX14 Headlight Bulb Type
04/22/09 8:55 AM
If you want to stay with halogen, I recommend these:
http://www.piaa.com/Bulbs/Bulbs-H11.html
ninjamaster
04/22/09 12:15 PM
I did the Piaa's last year.WOW!!!!$200 well spent!
Steven14
04/22/09 12:54 PM
Absolutely, even though I have HID low beams, the high beams are PIAA H9 Xtreme White
http://www.shopatron.com/product/product_id=PIA70955/353.0
redtrace
04/24/09 8:56 PM
I am running the same set up on mine. The HID's are just what this bike needed. I also changed out the marker bulbs to 1 watt led's from this place: http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=CAR
It is part number WLED-NWLX and the cost is 9.95 each. I got them in natural white which has a 6000k color temp that matches my HID's. These things are way bright!
* Last updated by: redtrace on 4/25/2009 @ 9:09 PM *
04/25/09 9:57 AM
It is part number WLED-NWLX and the cost is 9.95 each. I got them in natural white which has a 6000k color temp that matches my HID's. These things a way bright!
I thought Natural white is 5000k ? I also changed all bulbs to HID 6000K Diamond white. LED lights are a match and they are are awesome. I don't use the high beams very often, but they are a great night time horn.
* Last updated by: Romans on 4/25/2009 @ 12:58 PM *
redtrace
04/25/09 9:15 PM
I don't use my high beams much either. Not much need with the HID lows. Since I have a halogen bulb for the high beam, when I do put them on, you can still clearly see the low beam pattern in the high beam spread.
I use them mainly for when I get flashed by oncoming cars that think my lows are too bright.
04/25/09 11:24 PM
I flash my high beam approaching country lanes when a family is sitting in the old Plymouth at the entrance to the road, as a horn / attention-getter. Anything to keep them from pulling out in front of me "because we didn't see him".
* Last updated by: privateer on 4/25/2009 @ 11:25 PM *
stimo
04/26/09 1:17 PM
Hey guys am interested in the Piaa bulbs can you put 4 of them in as low beam and high beam and do they draw more power from the bikes electrics and those leds where did u put them redrace or are the H9s just a high beam bulb only.
redtrace
Steven14
04/26/09 7:47 PM
stimo
04/27/09 12:47 PM
Hey thanks steven for the info what colour are your leds natural white? and can I just put the piaa bulbs straight in and remove the halogen cheers .
redtrace
stimo
04/28/09 1:03 AM
Thanks redrace so do I get piaa h1155 for low beam and h9 65w for high beam is this correct and i appreciate the help seems no one over here has done this yet.
04/28/09 5:13 AM
Absolutely, even though I have HID low beams, the high beams are PIAA H9 Xtreme WhiteI am running the same set up on mine. The HID's are just what this bike needed. I also changed out the marker bulbs to 1 watt led's from this place: http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=CAR
red, is the WLED-NWLX led a direct replacement, or do you have to make/buy anything else to use them ?
redtrace
04/29/09 7:04 PM
privateer...Yes, the LED has the same base as the original bulb. It is a bit longer, but it still fits with plenty of room.
Stimo...Yes, those are the correct choices. Although, I would really consider changing your low beam to an HID set up. Once you've seen how well they work, you'll never want to go back. Here is a link to where I got mine. They have the slim digital ballast that is much more reliable than the older, bulky ones. www.xeonbargins.com
The kit is 129.95 and that is for 2 bulbs and ballasts.
jrp0629
CycleJunkie
04/30/09 10:47 AM
Thanks for the info Red & Steven.
Red's link should be http://www.xenonbargains.com/
dennisclawson
04/30/09 2:06 PM
jrp My first "test" of my HIDs didn't work either.
In my case the problem was that one of the connectors wasn't making solid contact.
Also check the fuse - its in the under seat fuse block.
Also I've heard the lights are +/- sensitive so maybe you have the wires crossed - simple to change and retest.
Can't think of anything else that could go wrong here... Never seen the bulbs blown so I don't know what to look for there.
-Dennis
redtrace
04/30/09 2:57 PM
jrp, as dennis said, check the fuse. I seem to remember mine popping the fuse on the first light attempt. If you read the specs on the ballast, it will tell you the max current draw. The replacement fuse has to be at least this amperage.
stimo
05/01/09 12:52 PM
so which kit do I need for just the low beams as there seems to be a couple on that sight and what colour 6000 or 5000k
Steven14
redtrace
