Not sure if anyone else has noticed this. I know many of you are very careful of how much oil you want to show in the sight glass so I thought it worth mentioning.
Yesterday, my bike was on the rear stand and I noticed the oil glass showed the oil level was at the very bottom. I just changed my oil before my trip and I know I left with the oil level right in the middle. My bike has always used barely any oil between changes so I knew this wasn't right.
I've always checked my oil level by wedging some wood under the sidestand so the bike is straight up. So straight that a breeze would knock it over. I usually have someone watch the bike while I get down to see the level. The oil is always at operating temp and I even keep the bike straight up after turning it off. I know this way is accurate.
My bike showed the oil at the very bottom of the glass while on the stand. When I placed the bike on the sidestand with wood under it and straight up, the oil glass now showed right in the middle.
Not sure how much oil it takes to fill the glass from bottom to middle but if you do add oil when on a rear stand then the actual level is higher than what you are intending. Since the glass is near the back of the motor a typical stand lifting the rear tire 3-4" will move the oil to the front of the motor and what you see in the glass isn't correct.
* Last updated by: KAK on 2/29/2012 @ 3:02 PM *
