Good recovery, Kruz. It's not luck but skill. We're done with the rim and tire. If you rather salvage the wheel, there are a few specialist out there to service that ding. Between you and I, take a wing of a plane and buckle it till you find the weakest wrinkle and it collapses. Lets go straiten it out and fly it and match hours to a non-wrinkled wing [model]. Lets also make it fly in the eye of the storm and that is what we will use it for, for the remaining hours of that puppy's life.
Around and around she goes, I'm more of a Ton'er kind of rider, so say we might stress crack the wrinkle coming back? I like to use a simple coat hanger [example] as that wing/rim/fork tube needing a straightening out some. So get a coat hanger or welding rod, bend it, then bend it straight again.
See the S bend? The bend is more like a short chicane or a wiggle. So it never really straightens out. Yes, I've bent back my share of fork tubes and reused them as per customer. The metal crease is scary in my eyes. The metal changes structure and I rather run fresh new parts. If someone wants to salvage it, sure it may never explode and all that breaking or chipping off. I'd offer it with the ding and see if you can salvage your money back buying a new one.
Would I salvage it, run it @ speed limit speeds? Yes. Would I use it when Ton'inn? Nope. I guess the rim is out of the way.
Next is bearings vs. shock springs. How much ding we have? Go to some city park, down the beach, pack some sand up and have some big rubber hammer to bring? Slam that ding out on some packed sand so the bottom gives out? That's meguyveer speaking rather than shipping it out. But say that's the deal. How much ding do we have? Did the springs take out [said pounds of] stress out of the bearings at the wheel? We need to spin the axle in the forks. If we can do that, slides in and out fine, we have the axle not so much taking the brunt on the way up the bearings. I'm thinking the front end is fine, no side load on the discs to distort.
Moving up to the steering bearings. How much ding did we leave here? These puppies are pretty soft and me packing the front end on [first] schedule: showed shadows of a ding. Not enough to center the forks you try to keep it there: then you have major divots she just hangs there. Even if a slight touch is to move it from center, she is trying to move out of that divot you can feel it happen. Here I'm thinking the fork springs, the axle, the combined bearings at the top and bottom took very little if not much of a hit at all.
If say the tire took a scrubbing and that's what it looks like, or say you had a warm enough tire to be soft and the lumber lobed one into the goo? Yes, you might [have] popped the tire off the bead, but you didn't. Yes, you might not feel a thing with the tire, or else it would have broken internally and caused it to leak. You rode it home, so if you let it sit and it holds air, sans how severe the rime is bent not to hold air, it's one more salvage call. Will the tire bubble at that area you keep an eye on it and the pressure?: sure, go shred. I'd square the rubber with the abs moves, so again, not a kind of Ton kind of tire for me. I'm all fresh up front.
