Yeah. I Have a valve cover leak and I can tell after I add oil, there is this sweet spot where I get max grunt. As far as using rear stands and a level to check your oil, it is not necessary I just had to do that to know for sure if and how much oil I was loosing. HOWEVER, we don't have the same physical attributes... I can lower my 14 till the pegs touch down and lift her back up for reps but if you dropped you bike or feel you will it is best you use stands. That has nothing to do with oil check accuracy.
