Thread: Wher 2 buy Vortex rearsets?
Created on: 05/15/11 06:07 PM
MATTZ14
MATTZ14's Gravatar
RE: Wher 2 buy Vortex rearsets?
05/17/11 5:05 PM
I have a set Darryle. I guess rook doesn't want em. call me9896193053save you some $ to.
Matt
07 Diablo black w/lots of STUFF
06 Ebony ZX14 deceased
trainedkilla
trainedkilla's Gravatar
Fort Mitchell, AL
05/17/11 5:38 PM
Does the rearset come with the shift lever?
2010 Special Edition Black/Titanium. Muzzy M10 Full System, PCV, F.A.I.C Map, NGK 9EK plugs, Vortex Shorty Levers, Vortex Rearsets, Vortex Rear Sprocket (43T), SpeedoHealer, EK ZZZ Chain, K and N Air and Oil Filter, Fender Eliminator, Smoked Rear Turn Signals, Galfer SS Brake lines (front and rear), Carbon Fiber Ram Air Covers, Custom Airbrushed Front Cowl, Driven Grips, Secondary Flies removed , blocked PAIRs and LC frame plugs.
MATTZ14
MATTZ14's Gravatar
05/17/11 5:46 PM
yes it does.
Matt
05/17/11 5:50 PM
Looks like you got the last set
knew my trigger finger wasn't lying to me. That's why I was hot to order. the ad said one set available and that was the fact, apparently.
Matt, feel free to post pics or whatever you want on this thread if it draws some attention.
* Last updated by: Rook on 5/17/2011 @ 5:53 PM *
trainedkilla
Fort Mitchell, AL
05/17/11 6:40 PM
Thanks Matt.
I don't know anyone with a 14 and just had a friend tell me that he thought the rearset was seperate from the actual rearset.
I have bought vortex rearsets in the past but the rearset and the shift lever were all connected.
05/19/11 9:09 PM
The Vortex shift lever is connected to the rearset and that is the case with all rearsets I have seen. The shift lever comes off of the Vortex and can be replaced. The stock shift lever is not used with any rearsets---if that was what you were asking. You take the stocker off. There is a rod that goes from the rearset shift lever to the shaft where the stock shift lever was mounted. The rod pushes/pulls on the shaft to shift up/down.
