If i bleed the calibers 1st will it drain the MC as well
Yes if you bleed the calipers first, that will drain the MC and the fluid reservoir which is located above the MC.
If you bleed the calipers first, the fluid in the reservoir will go down the tubes to the MC. To avoid this, you should be taking the time while you bleed to refill the reservoir. DON'T let the fluid level drop to the bottom of the reservoir. If this happens, you will just be sucking air into the system. You want to be squirting air bubbles out with the fluid you bleed from whichever bleed valve you are working at the time. Not the end of the world if you suck air in....you just need to fill 'er up start over! More practice!
or i would still have to drain and then bleed each component seperately regardless of which i do 1st??
If you drain the MC ONLY and do not get air into the lines or the calipers, then you will really need to bleed the master cylinder only (but I would still do both to be sure you have 0 air in there). If you drain the caliper then you have air that needs to be sucked out of the caliper....but that air can also rise to the MC...or it may just rise to the line between the MC and the caliper. For this reason, you will need to bleed both the caliper and the MC. As mentioned previously, Niti, I would suggest you bleed both MC and calipers forward and backward a couple times. Remember to rap gently on the lines and the MC and the tube to the reservoir to dislodge any air bubbles stuck to the insides of the system.
This is not rocket science. I was freaked out to bleed my brakes and clutch the first time but once you do it, you see it is not so mysterious. Do it 3-4 times and you are a pro. You start to develop your own technique. You know what is going on in there. Most crucial thing is do not crank on the bleed valves while you are opening and closing. Use a small torque wrench to tighten when done but go real easy on the threads while you bleed.
* Last updated by: Rook on 3/3/2014 @ 5:51 PM *
2024 ZX-14R bran friggin NEW!
