'89 GS ~ Had an output shaft seal leak. I could not fix the thing with the special tool, a new metal seal collar too. I forget if I sold it as is or had it fixed by the more skilled in that bike category; I gave up!
'9? GS ~ Had the gear box drained a lot. Could see brass each time I changed the oil. Kept seeing more each time. I said, no way am I going through this again. Sold it to anyone that showed up and obo'd me.
'06 ~ Had zero problems within that short 2K mule run.
'08 ~ Had the cam chain noise right after a dyno run > My fault, not the delicate tensioner system. Had a regular service interval and lost prime on a clutch master:
1. CCT-R; for cam chain tensioneRattle. The field fix idea is I had an idea on the cct. Took the one spring, wound it tighter around the ratchet plunger. That stopped the common/typical/some cct's will noise up on start up. Not mine. Thus begins the legendary, Bullet...
2... Proof, as in, "This side of..." Next, came the air in the clutch master. I know around here, some get LAP'Did [they], others get GAS'D (go and sit down)! That is when I dropped the ball, or more, dropped passed the bottom of the holes, did the lever catch air then. I then used the master's air bleed nipple and with one squeeze, the next was a waste, I should have stopped with one simple open/close, I had it on the one squeeze off. I lost that inch of freeplay. Hey, I was back to that 1/4 throw I know.
3. Recap my valve crap?; You mean, that is it? Yes, that is all I have to report as I snort; I've blown so many shifts, and I mean a good one the other day; I stab her up and down thinking this is it! Not one bit! She is in need of a sync but not really. The tune is off because this is about all that needs tuning on this thing... sans a valve inspect.
And for me to hear someone that caused the air pocket, can't get a lever back; Someone else shims a leak with a washer? Someone else removes a cover, I don't remember if that was reused or a new gasket(s) installed? Either way, someone has a leak/seep. And there has yet to be a bulletin out for anything other than, a tight bolt on a knock over switch, and a frame recall on a few and no others to report year after year.
HelLoooow? <<< I'm Dev Resivep and I whatever dis message.
* Last updated by: Hub on 11/27/2011 @ 4:00 PM *
