Thread: cruze control
Created on: 01/03/10 12:15 AM
lytnin
lytnin's Gravatar
cruze control
01/03/10 12:15 AM
Have been trying to figure out where to put a vacuum pod on the 14 for the cruze control. I was at the beemer dealer today talking to one of the mechanics and he said do like beemer and use a miniature vacuum pump for the cruze like beemer does.
I cannot believe I was to stupid to think of this BUT looks like my 14 my have cruze this year.
RE: cruze control
01/03/10 8:30 AM
If you need a vacuum source, why not use either #1 or #2 throttle body sync vacuum nipples. Cylinders 3 and 4 use these for the dump and pump, meaning, vapor lock the tank/emissions. I would agree, you may find a remote pump would give you a more linear throttle -reapply. The cylinder plumbing may be kind of chunky waiting for the other 3 to come around before the next suck occurs for the cruise system.
Find a crashed Honda GL or even an old one for sale with the OEM cruise. Salvage the cruise unit out of it. Either way, I would be holding on tight, that cruise wants to reset back up to it's programmed speed >>>
RE: cruze control
01/03/10 8:59 AM
Here is another thing. Duct or clear, wide packaging tape and a tube of GOOP brand glue are your drill and drill bit. Say you have room or an open gap where you if you looked inside the front fairing, there is someplace you could wedge that pump into place. Say the way to do it is to drill through the fairing to mount it up.
See, all you need to do now is to find the 'touch points' to the pump to that spot on the fairing, side cover, or winker cavity; are 3 areas I can think of right off the bat. You have a lot of options because you think, 'I need to drill to mount' is your only option. Forget about under the seat as you can see.
I found my touch points to the throttle actuator, glued them in place. She has seen 140-plus so far on her surface and she is still hanging out in the wind waiting for more. That is how strong that glue application can be.
Go to a home center type chain store, then look for that brand name. Or google "GOOP glue" with capital letters. Then watch the flash build a ball and chain kind of glue my bowling ball to my TV together kind of strength. Once you find your mounting hole, glue your touch points, run a strip of tape over the pump or the pump will slide. You'll see what I mean as how to work with the glue. It takes more than 24hrs for the glue to setup before you can push or pull your air tubes off without the unit moving. You could pull the tape off within hours of setting up. But, I find 48hrs is cured better, where you can apply more pressure on the unit from moving any. The best part about this glue is you can peel it off. Looks like it was never on the bike, fairing or paint.
Just throwing out an option no matter the size of that pump >> Glue it in place.
JDC
JDC's Gravatar
RE: cruze control
01/03/10 10:41 AM
I put on a Rostra system. Pretty easy overall.
https://zx14ninjaforum.com/messages.cfm?threadid=BDFAD98C-1372-66AE-3B2ADC081E6FED8E
after shelving and then cleaning up the wiring on the left side, you can see the main control unit clearly. I red outlined the direction that the cruise control cable followed when done. I don't recall a vacume on this unit.
* Last updated by: JDC on 1/3/2010 @ 11:09 AM *
lytnin
lytnin's Gravatar
RE: cruze control
01/04/10 8:07 AM
Damn this is starting to look easier all the time!!!!!!!!!!!!!!!!!!!!!!
