Like I mentioned above-you want to tighten the bolts to just where you see the gasket seal "beginning" to slightly deform from being squeezed.Stop at that point,front and back(under the rubber skirt on the rear one).Gasket seal should look slightly wavy as it runs along the front bolt side,along the outside edge,and back around the rear corner of the valve cover.You don't want to overdo it.Even if it's not at the torque spec while tightening the bolt(s)-I'd stop.I also put some red(!)locktite on the bolt tips (after cleaning them off),then installed.It'll take a few hours to get the residual oil out from the gasket-so just check it and wipe away any oil around the area.The test is when ya start er up and give er a run.You'll get some more oil most likely,a small amount,but it should completely stop by the next ride.Wipe that whole area clean at first-the valve cover top,sides,and rear behind the engine there.Any extra is gonna flow down to the seal area after it gets hot, and sitting on the sidestand.It may have blown up under the stick coil rubber cover-clean all that off really well.
* Last updated by: blue07 on 1/13/2010 @ 4:10 PM *
