EDIT, 08/09/2014:
The most recently updated parts are
Head Cover Gasket, part # 11061-0738
Ring-o, part # 92055-0143
PARTZILLA LIVE CHAT
Please wait while an agent prepares to assist you...
You are currently at position number 1 in the queue.
You have been connected to Shannon R..
Shannon R.: Hi Daron, I see that you need assistance regarding: Why do I see 2 of the same parts listed with dif part#s?. Please hold while I review your request.
Shannon R.: It could be that one part supersedes into another. Please provide the part numbers.
Daron : GASKET, HEAD COVER
Daron : 11061-0738 and 11061-0328
Shannon R.: 11061-0738 is just the newest part number. It superseded from one to the other.
Shannon R.: So you can order by either number and will get the same part.
Daron : ok, thank you. One more for ya. Ring-o 92055-0143 and ring-o 92055-0187
Shannon R.: I show the original to no longer be available so this is the reason for the part number change.
Shannon R.: I will check that one for you.
Shannon R.: Are you seeing those on the same diagram together, the last two?
Daron : Yes. on your page headed: Kawasaki Motorcycle Parts 2010 ZX1400CAF Ninja ZX-14 CYLINDER HEAD COVER Diagram the url is http://www.partzilla.com/parts/search/Kawasaki/Motorcycle/2010/ZX1400CAF+Ninja+ZX-14/CYLINDER+HEAD+COVER/parts.html
Shannon R.: Thank you. I am going to look now.
Shannon R.: That has to be an error on the site. There is only one o-ring, part number 92055-0187
Shannon R.: One part number for the o-ring I mean.
Shannon R.: I am viewing this model from Kawasaki software.
Shannon R.: Are there any additional questions I can answer for you?
Daron : Oh, yes. To clarify, you only have ring-o part # 92055-0187? The 0143 is listed elsewhere on the inet. Which is the most recent part?
Shannon R.: That is the correct. The 0143 is a valid part number, just not for the same application.
Shannon R.: One does not superseded into the other.
Shannon R.: These are two different o-rings
Daron : so, for the ZX-14 cylinder head cover bolts, part# 92055-0187 is what I need, right?
Shannon R.: 0143 is the oring that goes with 92153-1016 flanged bolt on the cylinder head cover.
Shannon R.: Sorry.
Shannon R.: Copy and paste did not work right.
Shannon R.: 92055-0187 is the o-ring that goes with that flanged bolt.
Daron : OK. THANS SO MUCH. That is a huge help. I will be ordering a lot more than just ringo-s so your time will be worth all the effort. thanks .Daron
Mine leaked after the dealer checked the valve adjustment @ 16000 Mi. (all ok) took it back and they replaced the gasket free with the new one - guess what?, still leaks ! going with the washers next - geezzz !
We have a couple stories just like this in this thread. Now I am throwing in my .02 SAme thing leaking fixed leak but not really it still leaks. Next thing to do is try the washers.
Let me get this straight. It is only the two bolts to the far left that get shimmed with washers?
oops sorry, didn't see we had two more pages tpo this thread. Well good I'll read it.
* Last updated by: Rook on 8/9/2014 @ 1:42 PM *
