Rick, in the linked thread that was with a +1 on the rear and Shane's was also a +1. Bobbybusa never said what gearing caused his issue but being stretched we know it was +something. I still say (not trying to argue at all) that there aren't any reports of "-" rear sprocket stutter problems. I do know my 40 tooth is not causing a stutter.
Bobbybusa bike did it with every gear he tried , and with two different ECUs.. At least that is what he told me on the phone on our many late night phone calls ..
My bike even with a 41 rear which is only down from the stock 42 had issues. Other 14s here also gone up to 43 and there was issues. If I could explain it I would.
On the circuit boards at work I have sensitivity adjustments. This allows me to adjust the Gain plus or minus up to 20 % In the back of my mind I'm thinking the sensitivity settings are different From Kawi from build dates. Or some versions of the ECU do not even look at that input. Fact is there is no science in the guessing game. Currently the only way I know how to solve this issue is to keep buying them until you get lucky. Which is beyond the scope of reality. 900 bucks a crack equals me out.
I should have bought Lees when he offered it to me. Yet i'm very glad Bob has it. Bobs passion for Drag Racing his bike shines through in every word. Congrats.
More on the same, click
I hope you don't take this question wrong. I'm hoping you know for our talking back and forth I really respect what you try to do and what you share with us. It is refreshing to see someone such as yourself who has a money making service that doesn't try cramming it down everyone's throat. You, Lee and Shane pass on a ton of great information for the rest of us.
toledo i'm probably the easiest going guy you're ever going to talk to. If you have any questions please feel free to ask. I will answer to the best of my ability. And if I'm wrong, please please set me straight. I test and try almost everything I read. Bull Shit floats to the top fast. To many have wasted good money on the pitch. You will never get that from me. It's our hobby, good intel helps us all.
So the question. Why are the flashes using the woolich software having the issue of corrupting an ECU when I don't recall ever hearing of someone with a Brocks/Guhl or Ivan flash having a problem. Does anybody personally (not heard from a friend of a friend) of anyone getting back a screwed up ECU for Don or Ivan?
Perfect Question. But, No matter how I answer it my view will be frowned upon. Better to play it safe on this one.
Ivan reads here sometimes. Maybe he will answer the question if he has ever had any trouble.
Brought my below comment over from 1441 as the current read appears rather Negative.
Please dont take this the wrong way. If you told me tomorrow I could no longer have the ability to make changes inside my ECU I would be devastated. With all I have going on with my own bike I would have blown it up by now. I need this to work. Example, Currently I have a 9lb Methanol Boost Flash running in high mode, 6lbs of Boost Flash in low. This all off the Handle bar. This was not possible before. I love it.
