meb,
'I'm assuming you followed the math.' No way. Well, if I knew the laws of (a+b) as opposed to a+b, meaning, no () is this another math move to do with them, right? See, I missed that move in the calc laws of this type of Find A and as you run thru the X to Y and finally come up with Z, it's the same concept of the reverse is Z = X times Y so the formula works either way you slice it is the law, the rule, something like that. If I only figured it out if they said, here's how a bike works. So back to ohm's law and those laws of math you need to build a motherboard and know where each part goes, build a miniboard and so on. I sure cannot build a motherboard unless I find all these clues first is theory.
With theory nothing can catch fire. The hard part is, this dragged me to someplace I found even more moves in the basic HC'ing. I hate using that term, but these are the laws of how to build a tone wheel window and think how that figures out in the timing, the software to say how to use the windows against each other.
'I'm even more impressed that it was published by a medical journal.' Where I found it, beats me? I open too many browsers when I'm stumped on a term like 'jump' and try to correlate how that term showed up in the abstract of another truth table.
'Prolly as the proof relates to medical chemistry.' I am traveling to places that chemically can only work mixing chemicals so this is somewhat related to chemistry, because without the parts moving as they do, then no can do. That was another travel stop and how I view this place called, wetletric is the earth.
'Anyway, so linear equations can be successfully approximated by other liner equations. OK, good.' Good and not good. The more I crawl up Ivan's and Justin's ass IS I am not going anywhere fast. No matter how much these guys know, how could I ask what I'm looking for so I am stuck looking.
Oh look, more absolute handcuffing abstract moves. Same moves no matter watt... NO MATTER WATT it's so beautiful the HC.
'This is important to prove in digital sampling systems (like an ECU with sampled sensors), and it is successfully proven...but, So what?'
Didn't you just walk up to a digital bike? Is not DFI a term in the book meaning, digital fuel injection?
So here is the 'so watt' no one can tell me. This is shop talk, so not too many are going to understand are more the few like you.
I am after that stumble. The why is why do some stumble with the same map thrown at it... This crapshoot at x and y. Some stumble, some code, some this and others that. THAT is watt I am after. That is a math attack in the chain of parts. What sets that set of cells once it X to Y's in that dimension is all I can think right now is a time vs. calc.
The more I dig, the more I have to think the software to hardware, no matter the soft, they can sell it in decimal is the pc. They can sell it in octal are Justin's cells. HTML and hex I'm sure could handle that software package, or say some code designer writes unicode who cares it says binary in the end.
I am after X to Y is that happening. Romes knows what I mean finding that 00000000000 starts the bike, swings the needles and they zero out the tone wheels, this that, everything is in sync is only one other move is current goes on to make it happen. So math wise, could the math close with 00000000010000000? That makes me think how could a good known ECU receive the same flash, poof goes the dash 39a or whatever the code.
Where am I? If I think with all those numbers changed on the cells, how far we've come in the speed and size of the chips and parts, if linear is the math in octal is Justin's pull from the ECU, it is like looking at linear numbers. If octal equals binary, then in the reverse is decimal, is one fat HC.
3 moves are input-calc-output.
6 moves are the next HC absolutes:
0. NOP = Do Nothing! (~~~~ Stumble?)
1. READ = Get Number the flashers put in.
2. WRITE = The number in the cell so they see it.
3. ADD = Add 2 Variables.
4. JUMP = Go to different program. (or.. Stumble Jump Shit in is JUMPshit out?)
5. JZ = Jump if answer was Zero!
1000ands of times it cycles: I don't want add the commas.
On to the next stumble is what the fuck is Jump? Lo to Hi? Hi to Lo?
