Thread: Rear Hugger With 190/55 Tire
Created on: 12/02/10 06:48 PM
12/02/10 6:48 PM
Anyone using a rear hugger with a 190/55 rear tire?
Is so, which hugger?
I need to get a rear hugger, but I am worried about my 190/55 tire rubbing on it. I had to take the hugger off of my 10r when I went to a larger rear tire.
RE: Rear Hugger With 190/55 Tire
12/02/10 9:13 PM
Good question, never even thought about that. Huggers are really cool but not cool enough to go back to stock size.
Also, if I got this right, I've recently been told that not all 190/55s are the same diameter.
12/02/10 10:09 PM
I ran 190/50 and the hugger fit fine.Remember...it's attached to the swingarm,so even if it's like "REALLY CLOSE"...it most likely won't contact the tire...unless your tire is able to flex like a dragster tire at powerup.I bought the Bestem hugger in CF.Will most likely be putting it back on soon....MAYBE...tonight.180/55 right now.Plenty of room..at least an inch,maybe more.It only hit when I lowered the rear an inch.It was then hitting the undertail(removed fender area).But it never touched the tire.
How much height is different between a 190/55 and a 190/50?Couldn't be too much could it?Okay...ya ,I see now...you want to go to the 55.Well,I would take a guess and say....yep...I think she'll fit okay.But there won't be any wide gap between.(they aren't called huggers for nuthin!)
Let me run this by ya....IF,now,I'm runnin a 180/55(which I am),and my clearance is very good width wise and height wise,then could I assume that the 55(width)would be the same on both tires....?IDK.And IF she cleared on the 190 for diameter height with an inch or so,could I assume THAT would be okay on another tire...a 190/55?Just wondering here...I truly don't know.Want me to measure the clearance when installed for ya?Sides and profile?
* Last updated by: blue07 on 12/2/2010 @ 10:23 PM *
12/02/10 10:21 PM
YA right there blue the PCD grows less than 1/4" as yer said it's set at 1" (fixed-swingarm) fit a semi in there
12/02/10 10:27 PM
Okay...ya...cuz mine fit my 190 with at least an inch to spare.The 55 width...no prob...plenty of room.Thanks Bean...trusting yer gettin along pretty good now...you'll be out ridin darn quick my mate!
I'm going out RIGHT NOW and reinstall my lovely Carbon Hugger!Thanks Dogo for the incentive here!I was gonna put er back on....just needed a little push!
* Last updated by: blue07 on 12/2/2010 @ 10:29 PM *
12/02/10 10:47 PM
To right there blue mission impossible the ergonomic degrees meas. said I need 36 more degrees Saturday (next week) for the Christmas toy run ! thats 4.5 degrees a day so I can ride the XJR1300 @ 98 DEGREES so im forcing the bending im @ 65degrees right now, can finaly go on the exercise bike to 360 degress stode slightly up ( could only do 270 degrees before Tassie ) now going up and down the stairs @ my house keeping all the updates of pictures for my modifide big REDZX-14, GOT Stuffed around with hugger got money back new stock arrives in UK 15 december, then comes out to here 3 more F---IN weeks !! yu f--in hooo cant wait, but hell I payed originally on september 9, Shit that means I can wait enough of my crap now!! have a "VERY MERRY CHRISTMAS BLUE" I hope Santa brings "US" " ALL" a better newyear !
* Last updated by: bean07 on 12/2/2010 @ 10:50 PM *
12/02/10 11:16 PM
Right on Bean...yer ridin days and good leg again are about to start over!!Way to go!I'm HAPPY for ya!And a way awesome Christ Mas time to ya also Bro!
Got my hugger back on now....there's at least two inches of side profile clearance,and just at one inch top center tread clearance.I'd say the 190/55 will be close at the center tread,but fine on the outside.That's with a BESTEM...can't say how another brand MIGHT be "profiled different" in the shaping dept.
* Last updated by: blue07 on 12/2/2010 @ 11:18 PM *
12/03/10 3:59 AM
"blue" ? Hugger !
* Last updated by: bean07 on 12/3/2010 @ 4:00 AM *
12/03/10 4:41 AM
i have the bestem hugger on with the 200/50 with no problem and on my zx 9 stock tire is 180/50 i have hugger on it with a 190/55 you should be fine
12/03/10 10:52 AM
Thanks guys.
When I put the 190/55 tire on my 10r, the hugger cleared the tire ok... but once I rode it down my gravel driveway, the rocks that would stick to the tire would rub the hugger. If there's an inch of clearance (stock tire) on the 14, that shouldn't be an issue.
12/03/10 2:09 PM
Check out 6th post on this thread. If you have 1/4 inch t o play with, that could be a problem depending on the exact model of 190/55 tire you have on there. They vary almost 1/4" in height according to this experienced rider/wrencher..
12/03/10 2:25 PM
Go to the "Newbies" section dogo! in the "Hi from Australia" (Cobain's bike)there is a good photo of his Hugger there!
12/03/10 5:04 PM
https://zx14ninjaforum.com/messages.cfm?threadid=DFA74EAF-D56B-84E2-1D9B57090C3426ED
Thanks Rook. I knew different brands and styles of tires vary in size... but a 1/4" for the "same size tire" is more than I thought. 1/4" overall diameter would only be 1/8" less clearance on the hugger. I already have bt016's sittin' here, and a hugger is on the way. If clearance is tight, I'll take size variances into consideration when I replace the Stones.
Anyone know of a good website for finding actual dimensions of different motorcycle tires? Something like TireRack has for car and truck tires???
J/K Bean. Thanks! Them pics is what I needed to see. That one looks like the Powerbronze?
russty
12/03/10 7:41 PM
I have a geelong carbon craft hugger with a Pirelli Corsa III 190/55.
The tyre fits ok, but the little bugger picks up gravel and carries it around for a rev or two scraping the inside of the hugger. The tyre didn't make enough of a change to the handling so my next tyre will be a 180/55 like I used on the R1 previously. Hoping for better handling again.
Soon after I had the hugger installed I went over a layer of gravel, picked up so much that the hugger now has several splits from teh gravel being squeezed through a tight space. This might not be an issue with another make of hugger. The Geelong Carbon products are beautiful, but they are lightweight (by design I expect) so they are quite thin and therefore susceptible to breakage.
I wouldn't repeat the same combination.
I may replace the hugger with another Geelong CC hugger at the same time as I replace the tyre.
08 sapphire
12/03/10 7:45 PM
The corsa III's rubbed my hugger ever so slightly,so I filed out the mounting holes,problem gone
12/03/10 8:14 PM
Thanks guys. Corsas have a bit taller profile than the Bridgestones. Maybe I'll be ok. If not, I'll do what I have to make it work. I ordered a Carbon Dynamics Carbon Fiber Rear Fender / Hugger
. It's cheap, so I won't mind cuttin' it up if need be, like I would a Geelong. I really like their tank protector, but pricey stuff. I'd feel bad about cuttin' or bustin' up a $400 hugger... $125, not so much.
12/03/10 9:25 PM
dogozx hey mate have you seen the Skidmax hugger? Ive got too on the way from sportsBikeShop ( UK ) MY ZX-14 and Goodies XJR1300 is a bit dearer ( $145-AU )each to OZ !
12/03/10 9:38 PM
SkidMarx LOL....
I'd have to put it on and go for a rip up...
LOL.
That one looks good, Bean. I just ordered the cheapest CF hugger I could find.
* Last updated by: DogoZX on 12/3/2010 @ 9:39 PM *
12/03/10 9:49 PM
12/04/10 8:58 AM
Is this the new "whacky street signs thread"??
12/04/10 9:02 AM
Sorry, can't get any bigger image. Photobucket screwup.
* Last updated by: Rook on 12/4/2010 @ 9:03 AM *
12/04/10 9:09 AM
12/04/10 12:00 PM
It is now. Sh*t you made me wait two years for those two, Rook.
12/04/10 12:30 PM
OMG dude, that's awesome!
Naw, man-- you were AWOL!
12/04/10 1:56 PM
I wasn't AWOL... I was AWL. I got a letter from the DOL... LOL.
